SStJ1979 Posted May 19, 2014 Report Share Posted May 19, 2014 Good day folks. I recently had to replace the slider in my BJR182. I have it in place and am now struggling with the chuck. According to assembly diagrams I have seen online, I believe I have all the pieces in the right order and positions. However, I cannot seem to get the driving sleeve to slide over the guide sleeve far enough to match up with the driving sleeve guide and sleeve. I am aware of the notches on the guide and sleeve for the bump outs in the driving sleeve. I also understand the the ramped portion of the driving sleeve in regards to putting pressure on the shoulder pin and compression spring. I just, for the life of me, can't get the the driving sleeve to cooperate with e the guide and sleeve. Anyone run into this difficulty? Quote Link to comment Share on other sites More sharing options...
Conductor562 Posted May 20, 2014 Report Share Posted May 20, 2014 I had a similar issue once because the chuck bolt wasn't screwed down all the way. Quote Link to comment Share on other sites More sharing options...
Andrius Posted August 12, 2014 Report Share Posted August 12, 2014 Hello, try to put spring number 15 to another side (not like in assembly diagram) and I think you will be good Quote Link to comment Share on other sites More sharing options...
