justin22 Posted July 28, 2015 Report Share Posted July 28, 2015 I have been looking for a weed wacker , I prefer Stihl and I already have an edger attachment, and I found a Stihl kombi Homeowner and the professional is it worth spending more for the professional? Whats the difference? Quote Link to comment Share on other sites More sharing options...
Justin Hernandez Posted July 28, 2015 Report Share Posted July 28, 2015 It depends on how much you will use it and the things you are cutting. The professional has a bigger motor and is a 4 mix engine type, I would always go bigger but if you are only using it for one property the choice is up to you. The professional line is much better and for a few dollars more its well worth it 1 Quote Link to comment Share on other sites More sharing options...
kornomaniac Posted August 4, 2015 Report Share Posted August 4, 2015 The professional is a 4-mix engine whereas the homeowner type is a 2 stroke.A 4 mix engine is the stijl version of a 4 stroke engine. It had the 4 strokes principe but still uses gas/oil mix to run ( just like a 2 stroke ).4 mix engine have more torque, use less fuel, less exhaust and sound not so loud.They do are abit heavier and have an extra maintenace step: adjustinng valves every 130 hours of use.Adjusting valves is some thing you can easily do yourself with a YouTube video next to you ! 2 Quote Link to comment Share on other sites More sharing options...
Charles Harris Posted August 4, 2015 Report Share Posted August 4, 2015 I've never regretted going for the pro line. I have one of the older 2 stroke pro line trimmers. FS80R Quote Link to comment Share on other sites More sharing options...
Justin Hernandez Posted August 5, 2015 Report Share Posted August 5, 2015 Stihl for life!!!!! 1 Quote Link to comment Share on other sites More sharing options...
justin22 Posted August 6, 2015 Author Report Share Posted August 6, 2015 thanks for the replys! and are there any big advanteges with the 2cycle? Quote Link to comment Share on other sites More sharing options...
Charles Harris Posted August 6, 2015 Report Share Posted August 6, 2015 Simplicity. Problem with the newer ones is all the crap on them to make them meet EPA requirements. Quote Link to comment Share on other sites More sharing options...
Charles Harris Posted August 7, 2015 Report Share Posted August 7, 2015 @ ProToolNut.Don't forget you have to mix gas and oil for the Stihl 4-Mix 4 strokes.I had a guy the other day argue with me that the Stihl 4-Mix was a two stroke. The only argument he could come up with was you have to mix oil in the gas. I tried to explain that is has valves and makes 4 cycles. It was like arguing with a fence post. We had to just agree to disagree. 1 Quote Link to comment Share on other sites More sharing options...
kornomaniac Posted August 7, 2015 Report Share Posted August 7, 2015 And 4 strokes arent neccesarily less loud but its a more lower tone prefable sound for me. 2 strokes have a higher pitched sound. Quote Link to comment Share on other sites More sharing options...
