Downshftking Posted October 25, 2015 Report Share Posted October 25, 2015 I like to work on cars and would like to know what would be the best thing to use that would be gentle enough to help clean my engine but powerful enough to clean my patio and my exterior walls?? Quote Link to comment Share on other sites More sharing options...
DR99 Posted October 25, 2015 Report Share Posted October 25, 2015 Something like this is good enough for home use just make sure you don't use a crazy tip when you use it on you car http://www.homedepot.com/p/Ryobi-3100-PSI-2-5-GPM-Honda-Gas-Pressure-Washer-with-Idle-Down-RY80940/203615829 Quote Link to comment Share on other sites More sharing options...
Bigmikez Posted October 25, 2015 Report Share Posted October 25, 2015 I think that's the same model I have DR not 100% sure I'll double check but if it is mine it has been great Chris I'm surprised u haven't seen mine yet I'll let u try it out next time ur down in riverside bro. Quote Link to comment Share on other sites More sharing options...
DR99 Posted October 25, 2015 Report Share Posted October 25, 2015 They also sell the exact same power washer under the Homelite name as TTI makes both of them. Quote Link to comment Share on other sites More sharing options...
Logan Posted October 25, 2015 Report Share Posted October 25, 2015 Something like this is good enough for home use just make sure you don't use a crazy tip when you use it on you car http://www.homedepot.com/p/Ryobi-3100-PSI-2-5-GPM-Honda-Gas-Pressure-Washer-with-Idle-Down-RY80940/203615829This would probably work Ryobi is a good brand Quote Link to comment Share on other sites More sharing options...
Downshftking Posted October 25, 2015 Author Report Share Posted October 25, 2015 On those power washers can you adjust the pressure or is it based on what tip you use?? Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted October 25, 2015 Report Share Posted October 25, 2015 On those power washers can you adjust the pressure or is it based on what tip you use??Usually they just adjust the spray pattern not the pressure itself.JimboSent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Downshftking Posted October 26, 2015 Author Report Share Posted October 26, 2015 So what do you or how do you adjust the settings on the washer with out compromising the power or pressure?? Quote Link to comment Share on other sites More sharing options...
DR99 Posted October 26, 2015 Report Share Posted October 26, 2015 Its pretty much just by swapping out the tips for more aggressive or a less aggressive spray. Some wants have a twist top that lets you adjust it even more you can idle the motor down more but its not good for the motor or pump really. Quote Link to comment Share on other sites More sharing options...
Downshftking Posted October 26, 2015 Author Report Share Posted October 26, 2015 Ok so do you have any or know any that you recommend as far as good ones out there!! Quote Link to comment Share on other sites More sharing options...
DR99 Posted October 26, 2015 Report Share Posted October 26, 2015 Talking about pressure washer? or the wand/tips they come with the pressure washer. Quote Link to comment Share on other sites More sharing options...
Downshftking Posted November 10, 2015 Author Report Share Posted November 10, 2015 I was asking about if there are different tips to use depending on the use or is it dependent on the power washer?? Quote Link to comment Share on other sites More sharing options...
rfwjr Posted January 4, 2016 Report Share Posted January 4, 2016 A lot of people like the Turbo Tips that deliver a rotating spray pattern. I like that Ryboi that Jason posted since it has the Honda engine and the soap chamber. Quote Link to comment Share on other sites More sharing options...
comp56 Posted January 5, 2016 Report Share Posted January 5, 2016 back in high school there was a girl.....oh wait you said turbo tips......sorry..... 1 Quote Link to comment Share on other sites More sharing options...
