wildroamer Posted June 12, 2016 Report Share Posted June 12, 2016 Hey gang, Well, I've gone and done it. I ordered a new Makita LS1016L SCMS! It will be my first miter saw, and I'd like to outfit it with a decent blade. From what I understand, I should probably be looking for a 10" with 60-80 teeth. I also am aware that with a slider, a small positive tooth angle, or even negative angle, is preferred. I a few Diablo makes one for a SCMS, D1060S. I believe it has a 7 degree positive angle. Thoughts? Quote Link to comment Share on other sites More sharing options...
JimboS1ice Posted June 12, 2016 Report Share Posted June 12, 2016 Diablo makes great circular saw blades, would probably get the 80 tooth then something lower for more rough cuts Jimbo Sent from my iPhone using Tapatalk 4 Quote Link to comment Share on other sites More sharing options...
Fazzman Posted June 21, 2016 Report Share Posted June 21, 2016 Another vote for Diablo blades here. Ive heard good things about Forrest blades too. 2 Quote Link to comment Share on other sites More sharing options...
wildroamer Posted June 21, 2016 Author Report Share Posted June 21, 2016 Thanks guys. I ended up buying a aFreud LU74R010 10-inch 80-tooth. I read some positive reviews, but haven't tried it yet. The blade that came with the saw actually seems like a quality one, with 60 teeth. 2 Quote Link to comment Share on other sites More sharing options...
John Glassey Posted June 21, 2016 Report Share Posted June 21, 2016 That's a nice blade too. I have several Freud blades. Great carbide on them can be sharpened several times. 1 Quote Link to comment Share on other sites More sharing options...
rfwjr Posted June 21, 2016 Report Share Posted June 21, 2016 I like the Diablo blades. 3 Quote Link to comment Share on other sites More sharing options...
Fazzman Posted June 25, 2016 Report Share Posted June 25, 2016 Freud and diablo are one and the same. Quote Link to comment Share on other sites More sharing options...
Hugh Jass Posted June 25, 2016 Report Share Posted June 25, 2016 That's way too many teeth IMO unless you're building cabinet grade projects. I run 44T Diablo's in my 12", if tear out is a concern when running door casing or the like, I just put a piece of sacrificial material against the fence...flawless cuts for less than half the cost. 2 Quote Link to comment Share on other sites More sharing options...
wildroamer Posted June 26, 2016 Author Report Share Posted June 26, 2016 3 hours ago, Hugh Jass said: That's way too many teeth IMO unless you're building cabinet grade projects... I'll remember that next go-around. Thanks for the tip. 1 Quote Link to comment Share on other sites More sharing options...
comp56 Posted June 26, 2016 Report Share Posted June 26, 2016 zero clearance insert helps that a lot too....have one on my 12" milwaukee cuts like a dream 2 Quote Link to comment Share on other sites More sharing options...
