Chuck/jaws spinning after releasing trigger on DCD791?
aabee
Hi all,
I've been looking at DeWalt's DCD791/DCF887 combo kit for a while and have tried it out at my nearest Lowe's, and noticed that when the trigger is released in second gear, the chuck and jaws continue to spin for a couple of seconds after releasing the trigger. Is this a common occurrence for the drill? My Makita subcompact doesn't do this and I noticed the Porter-Cable 18v brushless doesn't either. Was just curious what the purpose of it is and if it was the standard way it operates. Thanks!
3 hours ago, aabee said:
Hi all,
It's just due to not being clamped and therefore loose enough to have momentum keep it spinning.
I recently got the DCD796 and it does this.
I've had a few bits fall out. It's like the chuck loosens due to the motor brake. I used it briefly yesterday and tightened the chuck a lot tighter than I usually do and the bits stayed in ok, although I feel the chuck was a tiny bit easier to loosen than I expected, so maybe it did loosen up a little bit but it's hard to tell.
Great drill!
