optimistspencer Posted November 4, 2015 Report Share Posted November 4, 2015 I am building a new workbench that is bolted into the garage wall, and I also want to bolt it to the concrete floor. I've never done this before, so I was hoping you guys could steer me in the right direction- should I be using a powder actuated nailgun or should I use concrete floor anchors?Sent from my One M8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
comp56 Posted November 4, 2015 Report Share Posted November 4, 2015 just get some red heads.....http://www.confast.com/articles/red-head-wedge-anchor-installation Quote Link to comment Share on other sites More sharing options...
Poisonfangs85 Posted November 4, 2015 Report Share Posted November 4, 2015 + 1 for the red heads. Use them all the time, They will do the trick for you no problem. Quote Link to comment Share on other sites More sharing options...
EEtwidget Posted November 5, 2015 Report Share Posted November 5, 2015 Although redheads are great, and the go to when mounting big stuff, maybe overkill for a workbench. One alternative are tapcon concrete screws. They are rated and approved by most city/state authorities and very easy to install. They come in a variety of shank sizes and head types. Sold right next to redheads and approved for cracked concrete.If you are setting lumber directly onto the concert floor you should use pressure treated where contact is made. Tapcons are recommended for this type of application.I used tapcons to secure a large steel manhole type cover over the tornado pit @ discovery science center. Lots of kids beating the hell out of the thing and it's standing strong. They come in the standard blue coated and stainless variety. Another benefit to tapcon vs redheads- no bolts or threads sticking up above the floor. Don't know if that matters to you.How secure do you need the bench?http://www.tapcon.com/products Quote Link to comment Share on other sites More sharing options...
optimistspencer Posted November 5, 2015 Author Report Share Posted November 5, 2015 I want the bench to be strong enough in the framing that I can beat the hell out of the surface- it'll be both a metalworking and woodworking bench and the goal is to have pretty much no vibrations when I'm hammering shit on an anvil or whatever else. I've used tapcons before, so Ill probably use those. Definitely not as fun as a semi auto PA gun tho XDSent from my One M8 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Gatorb888 Posted November 5, 2015 Report Share Posted November 5, 2015 You can use "wedge bolts" aka concrete screws. What's nice about these is they are removable. Expansion anchors are not, you have to cut them. http://www.powers.com/product_7204SD.php Quote Link to comment Share on other sites More sharing options...
EEtwidget Posted November 7, 2015 Report Share Posted November 7, 2015 Just use solid 4x4 or stacked 2x4 for the legs. Don't even bother attaching to the floor or wall, should be enough weight to hold steady. Quote Link to comment Share on other sites More sharing options...
