Yog Posted August 25, 2016 Report Share Posted August 25, 2016 I got myself a used,beat up Makita BHP452 from ebay for my house reno project. It works, it drills. This my first drill.... what do I need to look out for on used Hammer drill, currently they have sparks coming out of the rear cover. And it seems to be having a "braking sound" (short screeching) whenever I stop drillling, Is this normal? I like taking care of my machines, I cant help it, especially if they serve me well. Thanks for any tips. If anyone want to get a used Makita in 2 months time, I'll be happy to sell. Ha ha! Quote Link to comment Share on other sites More sharing options...
Bremon Posted August 25, 2016 Report Share Posted August 25, 2016 Sparks are normal. The braking sound is also normal I would guess. Only thing to really watch out for are the carbon brushes, and they go infrequently and are cheap to replace. 1 Quote Link to comment Share on other sites More sharing options...
Yog Posted August 25, 2016 Author Report Share Posted August 25, 2016 OK, just the brush. I got scared of the screeching brake sound cause I have my friend's corded AC hammer drill, and they slow down gracefully. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
jeffmcmillan Posted August 25, 2016 Report Share Posted August 25, 2016 Theres an electric brake when you release the trigger which is probably what youre hearing but it should sound more like a clank than a screech but it depends how fast you release the trigger. The sparking is probably normal but its worth pulling the back panel to check the brushes. The back panel is separate so its two screws and easy to put back on. I dont know why you'd plan to sell it. Mine is still chugging along nicely. 1 Quote Link to comment Share on other sites More sharing options...
Yog Posted August 25, 2016 Author Report Share Posted August 25, 2016 Finally, ah fellow BHP 452 user. It works fine. But would probably have no use for it after my renovations complete. So, it is a brake... that's nice to know. Quote Link to comment Share on other sites More sharing options...
Pushead Posted August 27, 2016 Report Share Posted August 27, 2016 And about sparks, when you inspect carbon brushes, you should also inspect that springs that push brushes are ok. And its good idea to lightly sand copper collector with P240 paper. Quote Link to comment Share on other sites More sharing options...
Yog Posted August 27, 2016 Author Report Share Posted August 27, 2016 Had it inspected at a repair center specializing in makita drill , turns out Jeff and Bremon were right, I let go too agressively. Apparently its in good working condition... with heavy cosmetic wear. 1 Quote Link to comment Share on other sites More sharing options...
Andrius Posted August 28, 2016 Report Share Posted August 28, 2016 Check carbon beushes and check armature ball bearings. And when you take motor apart check yoke unit for dust or some dirt on it. Clean dust from switch with air compressor. Then check if your chuck not moving from gear assy, because its ball bearing inside and some times its need to be replaced. And clean batterie contacts for dust for good connection with batterie. If you will burn it I can buy it 1 Quote Link to comment Share on other sites More sharing options...
Yog Posted August 29, 2016 Author Report Share Posted August 29, 2016 Wow, thanks for the tips. I knew somebody will know something, this is really useful! Thanks Quote Link to comment Share on other sites More sharing options...
CATERPILLAR Posted November 13, 2016 Report Share Posted November 13, 2016 just fixed one brushes , gear box switch Quote Link to comment Share on other sites More sharing options...
