Jaybird Posted January 3, 2017 Report Posted January 3, 2017 I know a guy that has a ton of pallets. Being the frugal person I am I have been wondering if I could build a workshop out of pallets. Any suggestions?
JimboS1ice Posted January 3, 2017 Report Posted January 3, 2017 You would need framing lumber then I guess you could use the slats for wallsSent from my iPad using Tapatalk
Hugh Jass Posted January 3, 2017 Report Posted January 3, 2017 40 minutes ago, SetBuilder said: Frankly that's 9/10's of the work.
KnarlyCarl Posted January 3, 2017 Report Posted January 3, 2017 46 minutes ago, Hugh Jass said: Frankly that's 9/10's of the work. That's true.... And to remove all the nails, well, I just throw the pallets on the fire and collect the nails later lol
comp56 Posted January 3, 2017 Report Posted January 3, 2017 if you go around eating out enough you can collect tooth picks and build a shop with them too, won't cost you a dime for the wood......by the time you conjure up enough pallets, pull them apart, yank all the nails cut them to size......may as well straighten all the nails and reuse them too.....na I'd rather sheath it with OSB for $8 a sheet give it a cheap coat of paint every 2 yrs and finish it in 2 long week ends 1
JMG Posted January 3, 2017 Report Posted January 3, 2017 You could always build walls out of them... http://www.naturalbuildingblog.com/pallet-houses/
JimboS1ice Posted January 3, 2017 Report Posted January 3, 2017 if you go around eating out enough you can collect tooth picks and build a shop with them too, won't cost you a dime for the wood......by the time you conjure up enough pallets, pull them apart, yank all the nails cut them to size......may as well straighten all the nails and reuse them too.....na I'd rather sheath it with OSB for $8 a sheet give it a cheap coat of paint every 2 yrs and finish it in 2 long week ends Until the big bad wolf comes and blows your shop down...Sent from my iPad using Tapatalk
Kato Posted January 3, 2017 Report Posted January 3, 2017 You can easily tear down palettes by running a sawzall down between the ribs and the slats, cutting the nails as you go. After that you just knock the heads out and you're left with good wood to use for projects. I wouldn't build an entire shop out of palettes but most of my shelving, workbench, etc came from palettes and crates.
Captain Obvious Posted January 6, 2017 Report Posted January 6, 2017 I'm in the process of building a firepit chair out of a couple pallets. I just used the reciprocating saw to cut the pallets down. It didn't take much time. I use the Diablo blades made for wood with embedded nails. If you want to get the nail heads out it's pretty easy.
Jronman Posted January 14, 2017 Report Posted January 14, 2017 @Jaybird depends on how much your building. Not sure if you would wanna use it for framing material but you could sure give it a try. I would make sure before you start by checking to see what the code requirements for palette wood are. Would be interesting to see what you come up with. 1
overanalyze Posted January 15, 2017 Report Posted January 15, 2017 On another forum I am on someone did it...and it looked like it. The labor to take apart and reuse the material far exceeds and real savings in my opionion. Save pallets for craft projects and...well..storing items to move with a forklift or pallet jack. 2
BMack37 Posted January 15, 2017 Report Posted January 15, 2017 46 minutes ago, overanalyze said: On another forum I am on someone did it...and it looked like it. The labor to take apart and reuse the material far exceeds and real savings in my opionion. Save pallets for craft projects and...well..storing items to move with a forklift or pallet jack. Plus, because of the crafts stuff pallets are no longer stuff that people pay to get rid of
ChrisK Posted January 15, 2017 Report Posted January 15, 2017 On 1/2/2017 at 9:10 PM, SetBuilder said: Hahahahaha
