so as I'm building shelving for the shop I wanted a small movable work bench so here it is ....not sure if paint is gonna get applied or not. I started with a stand that I put nice heavy duty casters on
here is how I did this as I wanted the supports to be screwed and glued...
the layout, I cut and put things in place drew lines where everything was, removed it all and drilled from top side right through I then applied glue and put screws in each end to hold everything. I then flipped it over counter sunk the holes and added all the screws. once the supports were in place and setting I cut plexi to surround the sliding drawers.....I only made 2 drawers but they are made so they can be both on one side or one on each......these drawers are fiction fit and will completely come out.....
  • Like 5
Comp it's always cool to see what you are going to come up with next. Great work man.
Looks good! Where do you findthe plexiglass?
i bought 8 cases of it from Target when they closed down, they used it for their shelving, none of the cases were even open I actually bought a lot of target stuff from their maintenance shop....thing was the store was so new almost everything was new. I got a lot of stuff that I still don't have a use for but couldn't pass up the price.
Millerz, just when you think comps done, he's pulls out some trick you've never heard of and makes it even more badass.
Jimbo
Jimbo
Hence my remark
thanks guys, if I had my way everything in the shop would be see through, I can't stand things in boxes or bags I can't see......I hate looking for crap, and if I can make it easier then I will.....
Register a new account
Sign in
    Michael321
    Michael321
