Quality Stud Finderl
Bloch98
If you have a Costco around you and are a member than their blue version of the Franklin 710 is your best deal, from what i understand they are identical. otherwise I would say go for something like the studpop or any other similar simple magnet type for around $10 or pony up for the Franklin 710 which runs around 50.. everything in between those just end up causing more frustration then they are worth
  • 3 weeks later...
This probably doesn't help you out since I see it's discontinued now. But mine is working well http://t.homedepot.com/p/Zircon-Corporation-StudSensor-e30-Stud-Finder-64129/202184883/
It has been dropped way more than I would like but it still works. I've used it so much, I have wore off the cloth pads.
  • 1 year later...
