Oil Changes revolutionized!
RickyMcGrath
Dealerships will hate it, or maybe not people still might not be bothered to do it by them selves even with it being that simple. The only thing is storing used ones will be difficult before they are recycled. That's a lot of flammable material right there
I'm sure they were designed to either be recycled or be reused. Unlike coffee pods oil is considered a hazardous waste so it has to be disposed of properly. Actually if they put a core charge on it people would probably turn it in for the oil to be recycled. People still dump used oil around sadly :(
funny how the pod is on the top ......all my years oil was gravity feed to the oil pan ......wait 10 minutes after turning off car let oil get back into pan......guess they have a pump when put into oil change mode.....
I can't see how this does a complete oil change. I'm thinking it only is designed to do a partial change. Which, of course is ok as long as you're using the same oil every time. A colleague of mine ran some tests on his 6.4 Powerstroke as he was getting heavy oil dilution due to the regeneration process and he changed out X amount every 1,000 miles, I think it was just a quart or two, out of 14 quarts total capacity, and he saw great improvements on his oil analysis.
I'm willing to bet there's going to be a healthy core charge on those things.
    Nick_T
    Nick_T
