Upcoming event.
Jronman
7 minutes ago, Jronman said:
oh more of a sheetmetal screwgun? I'm itching to get the new track saw but it has a few weeks yet before release. I wish it had bluetooth for the upcoming bluetooth vac. Maybe there will be a 60v tool connect adapter.
I'm just stoked for new 20v grinders. I use cordless grinders as a cut off too as opposed to a grinder/sander as such and none of the dewalt grinders are ideal for that atm
I have maybe used a grinder twice at work and it may have been the only times in my life. I should get one sometime. Might be useful at work. Add a backpack vac and a dust adapter, and you got a nice setup for work. Hopefully DeWALT makes one. I could see it being a dual battery flexvolt. Maybe could have a switch from 120v mode for extra cfm to 60v mode for more runtime.
I do a lot of renovations so there are often random nails or old stripped screws or pieces of steal or pipe or reo that need to be cut. They are often in awkward places where getting 2 hands in on a tail style grinder just isn't possible or under a house or something. Dewalt kept on making them and I have kept refusing to buy one, I own two Bosch grinders a Hitachi and no dewalts even though I have 10 plus 20v and flex volt tools. What cordless grinders are good at in general is cutting not grinding off large amounts of material so I've found it odd that dewalt kept making cordless grinders in the tail style when literally  every other brand realised that wasn't the right form for a cordless grinder
Hmm. That fan is very reminiscent of my M18 one which I'm not incredibly fond of but the fan does have more thoughtful features; adjustable speed via a dial first and foremost.
Also answers any any question regarding the concrete nailers power source; battery only. No cartridges.
Hope that fan is at least as powerful as the Ridgid fan..maybe more POWA?...if it's half as much like the Milwaukee that will .."blow" ..
    that concrete nailer is a nice tool,but I'll have to stick with Hilti because I need to nail to steel also...too bad..
Seen pictures of it firing pins through a steel beam.
17 hours ago, Framer joe said:
Oh,,no shit ! @Hugh Jass,  @Bremon that video above just said concrete nailer...and I assume when you say pins you mean nails,with a head on them ?.....if so then one could nail a pierce of pressure treated lumber(2x8)  to a 1/2" steel beam ?
I don't think it would have enough ass to fire through 2x and then steel. Actually I don't know of anything that does short of nitroglycerin, lol. But for attaching clips and whatnot, still very useful. Maybe if the steel was quite thin but I think it would lose too much inertia to penetrate much after 2x.
As for the semantics of pin vs nail, same thing but Ramset calls them pin's thus so do I.
Thanks bro,,,,,ya we attach 2x? Pt stock to the top/sides  of steel beams and shoot them on with "black" shot from Hilti can't even use the " red " shot which is for concrete ....but the vid did say it can shoot thro 2x pt stock to shoot a "plate" to the cement floor....but I didn't think it could into 1/2" steel without a .22 cal blank that Hilti uses.......thank you
need 6mm or about a 1/4 inch penetration into steel typically, as the heat generated helps bond the steel to the pin. It looks interesting but I suspect the more limited pin depth will make it quite niche. I currently use a Hilti 10 shot that shoots up to 3 inch nails with charges. If it can secure a 4 by 2 to concrete or steel or even something a bit thicker than a 4 by 2 it will be useful otherwise it is pretty specialist
5 hours ago, framer said:
any other tools in the works?  i'm still waiting for a left blade saw.
go to the Red Side........Milwaukee has a lefty saw
left blade is coming but will be worm/rear handle style instead of normal style. If it uses a worm drive mechanism or a similar mechanism to the rear handle x2 is unknown.
A new vac is in the works that not only meets the silica requirements but exceeds those requirements to allow it to be adequate for mdf. I don't know if it will be the larger 8 and 10 gallon vacs or if it will be the smaller cordless vacs. Would be cool to see a full size 120v flexvolt vac that could also use the corded adapter.
    PhillySpecial1
    PhillySpecial1
